Old May 25, 2004 | 06:45 AM
WesMichaels's Avatar
WesMichaels
Default
Originally Posted by Sunny9850
I almost hate to side with James...;-) but the fact that you have only a single cam doesn't make CVT impossible. There are a few types around that combine a "fixed" and moveable lobe on a common shaft. How the actual adjustment is accomplished varies, but the end result is the same.
But it is also a fact that this is definitely not the way to keep costs down :-)
I didn't say that a single cam was not possible. My only point is that it seems to me that it would be much easier and less costly to use 2 cams... Or even solinoid rather than trying to grind a single cam with the variables that are needed to really accomplish the power improvements desired. I'm a firm believer that not very many things are impossible but there are a huge number of things that are cost prohibitive or impractical.
