Old Dec 5, 2007 | 11:09 AM
huudoo's Avatar
huudoo
Default Re: What AMG motor is under our hood?
-- CHRYSLER CROSSFIRE SRT-6 M112 is a V-6
SLK32 AMG 2001- 2004 3.2L M112 V6 264 kW (354 hp)
- Vehicle type: front-engine, rear-wheel-drive, 2-passenger, 3-door coupe
- Price as tested: $45,695
- Price and option breakdown: base Chrysler Crossfire SRT-6 (includes $875 freight), $45,695
- Major standard accessories: power windows, seats, and locks; remote locking; A/C; cruise control; telescoping steering wheel; rear defroster
- Sound system: Chrysler AM-FM radio/CD player, 6 speakers
-- ENGINE
Type: supercharged and intercooled V-6, aluminum block and heads
Bore x stroke: 3.54 x 3.31 in, 89.9 x 84.0mm
Displacement: 195 cu in, 3,199cc
Compression ratio: 9.0:1
Fuel-delivery system: port injection
Supercharger: IHI, Lysholm helical type
Maximum boost pressure: 14.5 psi
Valve gear: chain-driven single overhead cams, 3 valves per cylinder, hydraulic lifters
Power (SAE net): 330 bhp @ 6,100 rpm
Torque (SAE net): 310 lb-ft @ 3,500 rpm
Redline: 6,000 rpm
-- DRIVETRAIN
Transmission: 5-speed automatic with manumatic shifting
Final-drive ratio: 3.07:1
Gear, Ratio, Mph/1000 rpm, Max test speed
I, 3.60, 6.9, 41 mph (6,000 rpm)
II, 2.19, 11.4, 68 mph (6,000 rpm)
III, 1.41, 17.7, 106 mph (6,000 rpm)
IV, 1.00, 24.8, 149 mph (6,000 rpm)
V, 0.83, 29.9, 154 mph (5,150 rpm)
-- DIMENSIONS
Wheelbase: 94.5 in
Track, front/rear: 58.8/59.1 in
Length/width/height: 159.8/69.5/51.5 in
Ground clearance: 4.9 in
Drag area, Cd (0.37) x frontal area (20.6 sq ft, est): 7.62 sq ft
Curb weight: 3,220 lb
Weight distribution, F/R: 55.3/44.7%
Curb weight per horsepower: 9.8 lb
Fuel capacity: 15.9 gal
-- CHASSIS/BODY
Type: unit construction
Body material: welded steel stampings
-- INTERIOR
SAE volume, front seat: 48 cu ft
luggage: 8 cu ft
Front-seat adjustments: fore-and-aft, seatback angle; driver only: front height, rear height
Restraint systems: manual 3-point belts, driver and passenger front and side airbags
-- SUSPENSION
Front: ind, unequal-length control arms, coil springs, anti-roll bar
Rear: ind; 3 lateral links, 1 diagonal link, and 1 toe-control link per side; coil springs; anti-roll bar
-- STEERING
Type: recirculating ball with hydraulic power assist
Steering ratio: 16.7:1
Turns lock-to-lock: 3.0
Turning circle curb-to-curb: 32.2 ft
-- BRAKES
Type: hydraulic with vacuum power assist and anti-lock control
Front: 13.0 x 1.3-in vented disc
Rear: 11.8 x 0.9-in vented disc
-- WHEELS AND TIRES
Wheel size: F: 7.5 x 18 in, R: 9.0 x 19 in
Wheel type: cast aluminum
Tires: Michelin Pilot Sport PS2; F: 225/40ZR-18 92Y, R: 255/35ZR-19 96Y
Test inflation pressures, F/R: 36/36 psi
Spare: none
