Old Dec 5, 2007 | 12:02 PM
ShawnQ's Avatar
ShawnQ
Default Re: SL55 AMG V8 Intake Conversion
Originally Posted by roncosrt6
Brian, does the SL55 Y fit the standard SRT6 throttle body or does that
need to be swapped out also?
Second-What is the diameter of the y tubes?
I would like to make my own CAI, one on each side..
The SL55 Y would make my job much easier if the diameter is
3 inches. I have everything figured out but the 'Y'...
The SL55 Y is not round, it is 'oblong', more of an oval. If you are using flexible pieces, you should be able to get a 3" piece to flex over it.
The SL55 Y fits right onto the SRT6 Throttle Body, no problem or modifications.
FYI - User named 'Marc' on mbworld.org has a Y-Pipe for sale, Y only (no intake tubes).
SQ
