Old Dec 9, 2007 | 12:44 PM
HDDP's Avatar
HDDP
Default Re: 3 port oil block
Originally Posted by Maxwell
I have an Earls store near my work, I'll compare prices and see what's available. I would really like to get it mounted down low, probaly have to pop out the lower bumper grill, I hope Don can make up a nice wiremesh grill for the lower bumper other wise I have to make one.
I don't want to block the radiator any more than it already is, since I'm building a fully molded fiberglass CAI that will mount just behind the grill and will accept large flat panel OEM filters from a v8 benz. this will obstuct the cooling radiator a bit but I hope it's not going to cause a problem with cooling.
You can actually mount it in the nook where the top and bottom oil pans connect... Build a bracket and weld it to the block so you can mount the cooler and still leave a 2" gap at the back for air flow...
