Old Dec 10, 2007 | 11:26 AM
Choppers07's Avatar
Choppers07
Default Re: Excessive tappet noise on cold start-up
Since it has only 34k is the 3/36 warranty still good? If so get it into the dealer soon, so you can verify the existance of the problem before the warranty expires. There are may possibilities, from chain tensioners, to valve train to piston slap, none of which should be occuring at 34k. If you bought it used, did you have the factory warranty transferred?
