Old Dec 10, 2007 | 06:14 PM
  #127 (permalink)
LantanaTX's Avatar
LantanaTX
Default Re: V8 Crossfire Conversion Diary
Here are some new pictures of the motor. I would have liked to have done more, but since this is still an unproven idea I have to keep costs down. As you read ealier, I washed the engine down to remove some aluminum oxide and then painted it with clear engine enamel. I did the same to the valve covers except I painted them Silver. I bought a kit off of Ebay that dresses up the stock engine cover. Let me know what you think! The new exhaust manifolds are on and if you compare these to what is currently in your Crossfire you will see that the stock exhaust will bolt up.
I really believe this engine has extreamly low miles. When I did the car fax it came back as 147 miles which I didn't believe. When I removed the valve covers everthing was pristine like it was just assembled even the inside of the valve cover didn't even have any oil stain discoloration.
