"The SRT-6 shares an awful lot in common with the outgoing SLK32 AMG, other than just the engine and gearbox. The dual control arm front and multilink rear suspension are virtually identical, although they are tuned in this application, with firmer damping and much stiffer spring rates. (They have gone up from 303 pounds per inch front and 337 pounds per inch rear to 451 lb/in and 480 lb/in respectively on the coupe.) The brakes, too, have come in for attention, with vented discs all around (the stock car has solid rear rotors), bigger front discs, and dual piston calipers in place of single-piston items."
