Re: SRT Engine vs Stock
Originally Posted by sonoronos
Ok, you are asking three different questions:
1. What's the difference between the M112 and M112 AMG? Most likely the entire top end of the engine, excluding the block and the shared sodium-filled valves. This would include rods, pistons, valve seats, valve springs, cams, bearings, lifters, injectors, intake and exhaust ports, etc. I'm quite sure that everything in the bottom end including the oil pump, water pump, crankshaft, crankshaft bearings, etc are identical between the two.
2. Can the stock M112 engine make 400 hp? In my opinion, yes! It comes stock with forged conrods, pistons, and has fairly good oil and coolant flow around the heads. Will it be reliable? CERTAINLY UNTIL IT BLOWS UP. Think about it. The engine is putting out twice as much heat as it was designed to, putting 17% more strain on the bottom end components, and there is probably some inflamed fellow behind the wheel. If you baby the engine, rarely rev it above 3000 rpm and only use the extra power for passing, then you will get more life out of it.
3. Has anyone done it? Probably not. Why would they? The stock M112 is an incredibly good engine and the rest of the car is a luxurious cruiser. It's a quiet cocooned interior that makes you feel like you are driving something special. Why would they spend money to change that?
The oil pump, water pump and crankshaft are different also. The crankshaft for the srt is almost double the price of the standard one.
