Re: Autostick Question?
I suspect it is how you are holding the shift lever when you are using the Autostick. If you hold it to the right it switches back to Drive, it dows't take a long time for it to switch back.
It only takes a quick tap to manually shift it, not the push it into gear kind of motion you would use with a conventional manual transmission.
