Originally Posted by tealcamaro55
Is there any donor car that you can grab lower ratio gears from? I'm guessing the suspension too is shared with the SLK.... Btw these cars have lsd's right?
A long time ago, I think someone posted that they found a Mercedes that used a 3.55:1 gear ratio, but whether or not it was the same "type" differential the Crosssfire used was not made clear.
Nobody, produces a "lower" gear ratio "ring and pinion" for this style differential any longer.
And no, Crossfire's don't come with LSD, not even the SRT. But an aftermarket unit is available.
Tealcamaro55, I use to have a 94 Z-28, 6 spd. "chipped" so I have a pretty good idea of what kind of performance you're accustomed to.
So unless you're going to be content with having a car that's probably (at least) 2 seconds slower in the 1/4 mile, than your Camaro, then you may want to consider a SRT.
