I have the Clarion SD card radio. No CD player. You put your music on an SD card and the faceplate folds down so you can insert the card. The radio is white, but it matches the dash very well. Plus, it has Bluetooth so when you get a call on your Cell phone, the call will come through the speakers in the car. Also has an external mic, which is optional to use. Heres the link....great price too.
http://www.crutchfield.com/App/Produ...larion&tp=5684
As far as the sub enclosure, take a look at my gallery. I was able to remove all of the styrofoam from the rear hatch to make 2 10 inch subs fit perfectly. The hatchback of the car works as the enclosure. I took the deminisions and bought a piece of 1/2 inch plywood. I cut the two holes for the subs, set them in, and then put some grey carpet over the wood. Added the amp in the middle. I was also able to place the factory cover right over the top of the amp and subs so nobody can see it through the rear window. Don't forget to put some Dynomat in the spaces that you removed the styrofoam from. This is needed to remove the vibrations from the sound hitting the metal directly. Feel free to PM me with any questions.
-Mike
