Old Dec 26, 2007 | 09:41 PM
  #125 (permalink)
NeedsWings's Avatar
NeedsWings
Default Re: group buy for asp pulleys for srt6
Thank you for the time you spent on the writeup, it is appreciated
First off, the intake kit was beautifully packed - a steamroller would have had to run over the package in order to damage the parts inside. The kit was complete with all required hoses and clamps and even a CD with installation instructions. It even had a license plate frame included - nice touch!.
My throttle body connection came off easily once I unlatched the upper clip. Not sure if the throttle body connection lower clip naturally releases after the upper clip is unlatched or if the lower clip was even latched in the first place. After what I've seen so far I'm beginning to wonder....... At any rate unlatching the lower clip will be a challenge so do the upper one first and then see if your throttle body connection can be rotated off without unlatching the lower clip.
Yes, once the top clip and the 4 valve cover grommet clips are loose you can tilt the entire assemble towards the hood and it will slip off the bottom of the TB, ill add it to the instructions.
Remove the passenger side horn from it's attaching bracket and remove the bracket also. My passenger horn wiring was routed in front of the main vertical bracket, not behind as shown in the instructions. This meant that I had to unplug the wires from the driver's side horn to be able to route the wire bundle over to the driver's side. This will make sense when you look at how the horns are wired. Remove the driver's side horn from it's bracket and the bracket itself. Needwings provides two brackets, one with two holes in it and the other with threes holes. Attach the longer three hole bracket where the driver's horn bracket was mounted. Attach the two horns to the bracket. The three holes in this bracket are not equally spaced but you should be able to figure out which end goes where. Don't forget to install the wires back onto the horns. I also tie-wrapped the wire bundle together where it folds back on itself between the horns.
Yes we installed another one tonight, I needed to unclip the 2 terminals on the driver side horn and reattach them once the horn was relocated, the xmas clip needed to be pushed thru from the frame to get the extra wire length. Ill touch up the instructions here aswell.
The radiator pass through piece is fastened in place with two pins as shown in the instructions. The vertically mounted pin in front can be pried off with a large screwdriver. The horizontally mounted pin on the radiator support bracket is far more challenging to remove. I resorted to knocking it out with a marlin spike boldly embossed with a warning not to use it as a punch. So much for heeding warnings. Unfortunately the pin popped loose and fell down under the radiator. It eventually wound up on the floor but to save yourself some grief put a piece of tape over the front of it so it won't go flying away.
Yes that pin in the back and getting the plastic piece out of the hardest part, the clips are a push thru type thru the center, we used a small phillips head tonight and popped it out for the back one and a pair of side cutters to pry out the front one (did not have to cut it off)
The pass through piece was a little difficult to pull out. Pretty much lever it sideways towards the driver's side and then pull it up and out. There is a nutplate (for the grill) above the piece and this nutplate can be pried off to provide a speck more clearance for removing the pass through piece.
The one we did tonight came out very easily, mine was little more difficult, just basically wiggle it clockwise (if you were looking down at it) with some upward pressure and it works it way out, i should have made a vid clip of it, i will next time i do one
The 90 degree coupler gave me all sorts of grief. It was just small enough that it would not slip over the throttle body with any kind of ease. About three quarters of it would fit on and I had to use a scribe to pry up the remaining quarter edge to get it on. I positioned it as best as I could and then clamped the coupler down so it would not pop off when installing the rest of the intake.
yes i agree it is tight and takes a minute to get it on, easiest way for me was to put my hand inside the 90 degree coupler while standing on the pass side of the car and just opened my fingers from the inside and it goes right on, we took it on off 3 times tonight and there was a few fumbles and abkano laughing at me but i bet i got it on everytime within 45 seconds. i went thru 6 different brands of silicone couplers before we found this one, all the others were either too tight or too loose, I dig the size and flexibility of that coupler very much, just barely loose enough to be able to spin it once on the throttle body for adjustment
I could not find the extra piece of felt to cushion the intake from the coil packs so I tie-wrapped a cut up piece of hose to the intake to act as a cushion. It's not pretty but it works.
Sorry it should have been in the goody box, ill drop some in the mail for you tomorrow
Went for a test drive but traffic prevented any good runs. The engine sounds more authorative, the pickup and throttle response seems better, and the supercharger does seem to pull more strongly once revved up. Further testing is definitely needed!
take that beast for a ride
Things to do still: Inspect the system to make sure nothing has come loose. Replace the cushioning hose piece tie-wraps with clamps - same effect but it will just look better.
Areas of concerns: The intake 90 degree coupling is under a lot of tension, at least in my setup. I spent maybe an hour fiddling with it and still am not real satisfied with the outcome. This is one area that I think needs to be looked at. Maybe have one end of the coupling longer, or redo the angle of the mating end of the intake, or maybe make the intake straight and use two 90 couplings. I'm just concerned that with the tension the coupling is under that it could slip off the throttle body.
Email me some pictures when you get a chance of the connection angles and lets see whats up
Another area that I'm not really satisfied with is with the filter and grill. My filter is up against the power steering cooling line and the grill. Needwings did a good job in fitting the filter in considering the space available but I'm just leary of the contact since I've seen too much damage from this kind of contact in regards to planes. I think I'll grind away the back of the grill for additional clearance, and pull the filter forward a tad to clear the power steering line.
Can you feel thru and see how much clearance ya got, I could slide my fingers all the way around the one we installed tonight, let me know where you think it may be too close please, the filter size can be adjusted but I didn’t want to go too dinky looking, we may be able to swap in a thinner longer filter, ill have to break out the big k&n book and see what we can try for ya.
Last area of concern is the two horns on one bracket. On a plane that bracket would be guaranteed to break from the extra weight. On the car this setup is probably just fine but for my own peace of mind I think I'll rig up a support for the bracket.
Sure, ill have to look when back under there if there is another mounting point for the bracket
Good job, Rob. Wouldn't hesitate from buying further products from Needwings.
Thank you and thank you for the indepth writeup, I love getting feedback like this, the usual... “hey sweet part, thanks” is always fun but that doesn’t make any improvements. I wish everyone did critiques. ill tweak the instructions on what I missed and do the research on that stuff I mentioned above.
