Old Dec 27, 2007 | 08:18 PM
Valk
Default Re: 12 volt hot wire?
Originally Posted by apkano
Do you own a voltmeter?
If so then attach a sewing needle (thinner the better) to one of the leads and just pierce through 1 WIRE AT A TIME until you find a 12v supply. You can just use a little silicone to re-seal the pinhole.
Apkano...Brilliant idea !!! I am looking for info on which wire is a 12V switched hot wire in the left windshield pillar. I want to hardwire my radar detector to a wire that is only hot when the ignition is on.
I read and posted this from another thread as well:
Originally Posted by FarbenKiber
For an '05 ROADSTER in the driver's side windshield pillar, the tan wire with green bands is a switched 12V line.
After I knew that, I followed an excellent FAQ on radar detector install from this thread:
https://www.crossfireforum.org/forum/...ead.php?t=4549
Does anyone know if this same wire is the switched 12V line in a 04 Coupe ??
