Old Dec 28, 2007 | 06:44 AM
Fenwick223's Avatar
Fenwick223
Default Re: Trouble Starting !?!
Search these forums for "Mystery No Start" and you'll find the solution. From one of my posts:
"Well, I think that we've finally solved the no start issue with my XF (knock on wood). This problem had been occurring for a couple of months and a few weeks ago the car stalled at a light and wouldn't start. In the end, a local dealer (Koons in Tysons Corner, VA) replaced the Relay Control Module. This module actually contains 4 control modules (including the fuel pump module) but is a single unit. Evidently a very easy fix in the end. You open the rectangular box next to the battery and the module is the part with the 40 amp fuse, 5 or 6 other fuses, and 4 or more connectors. You pop out this entire unit, disconnect all the connectors, pop it back in and close the box. Since I got my XF back on Monday, it's started every time and, maybe it's my imagination, but seems to be running better than ever."
Lots more detailed information in the entire thread. Good luck!
