Originally Posted by Maxwell
regarding the mechanical fan, you might be able to use the older E-class model 124 with viscous clutch, as I've read in a mercedes manual that you can adjust the temperature at which it engages. The book is printed by Bently press, it's a buyers guid for 90's model 124
The fan/clutch and shroud from any C43/C430 will work, but I didn't want to waste HP running that kind of fan. I am going to try these F.F. Dynamics 12" fans and see what happens. If needed I can go with the C430 C43 set up latter.
