Originally Posted by 240M3SRT
WTF guys!!!
I was hoping i wasnt the ONLY one. I just bought the car with 450 miles on it. The carfax was clean and the car looks flawless except for this...maybe i really am just an OCD **** retentive SOB but i just spent the last two hours taking measurements of the striker and what not and have yet to come up with a solid conclusion. The striker is NOT adjutable. When you remove the 2 torx screws you see there is a plastic insert and it has two alignment tabs so it can only be installed one way.
I will also like to note my car is black maybe this makes it more appearant. Also, the area that appears un-flush is only the area from the door handle up....from the door handle down looks fine.
If i push hard on the upper part it looks better aligned until i let off, then it goes back to where it was...this almost leads me to believe the rubber seal is thicker than it should be up top, but that sounds rediculous.
I must be on crack....but this is really irking me.
Thanks to everyone who actually went out and checked.
I happen to be in the same boat as you, 6000 miles on a clean Carfax 05
Alabaster Coupe. The drivers side door only has EXACTLY the same "problem" as you have described here. The only reason I haven't looked at it now, is the fact that it is covered up in the garage for the winter right now.
I'm sure as I start driving, cleaning and waxing the car again, it will freak me out too. This car was definately never hit! I have only owned it for a few months, so it hasn't hit me yet. I know the person it came from, so I know it background is good.
Happy New Year to All
Paul
