Thread: Help Please
Old Dec 29, 2007 | 11:55 AM
maxcichon's Avatar
maxcichon
Question Re: Help Please
Originally Posted by dyezak
Just found this on another thread:
"Well, I think that we've finally solved the no start issue with my XF (knock on wood). This problem had been occurring for a couple of months and a few weeks ago the car stalled at a light and wouldn't start. In the end, a local dealer (Koons in Tysons Corner, VA) replaced the Relay Control Module. This module actually contains 4 control modules (including the fuel pump module) but is a single unit. Evidently a very easy fix in the end. You open the rectangular box next to the battery and the module is the part with the 40 amp fuse, 5 or 6 other fuses, and 4 or more connectors. You pop out this entire unit, disconnect all the connectors, pop it back in and close the box. Since I got my XF back on Monday, it's started every time and, maybe it's my imagination, but seems to be running better than ever."
I've read many posts about this problem, some quite old, and it always came down to this "relay Control Module".
Maybe this should be a sticky?
