Originally Posted by cruzinquick
If your in drive and moving and put it in neutral you can rev all you want. Not sure how the dyno pulls are being done, but I was surprised that I was able to rev to redline by doing this. When you put it back to drive it does take a second or two to catch back in gear. I wouldn't recommend putting back in drive while your redlining. Not like the old days when the chevy was cold and just revved the motor to keep from shutting off and slammed into gear. Gone, no wonder that 350 turbo needed rebuilding.
If the dyno pulls are being done properly, you have to have either a dyno that also rotates the front tires....or the Star software from Mercedes that allows you to bypass the electronic "nanny".
without either of these, you an just do a dyno run to 4000-5000 RPM, not all the way to redline.
