Re: Thoughts? - battery. alternator or other problem?
did you check the strength of the electrolyte? I'm sure the battery cells are good, but if you don't drive it everyday theelectrolyte will get weak., you can buy fresh acid from pepboys if required, if a cell is getting worn I would replace with a deep cycle marine battery, since you let the car sit a lot.
