https://www.crossfireforum.org/forum...ad.php?t=16592 I put mine in the mirror I wired it to the lights. But i was going to wire it to the wing cause that is really the only time I figured I would need it. I still have the mirror with the monitor in it... It needs some work, I decided to paint the mirror because I was having problems seeing out of the mirror and end up with a run. It would need to be sanded out and repainted. I am a perfectionist you might not even care or notice it. It works with that camera system, I AM SURE OF IT BECAUSE I WENT THROUGH THREE CAMERAS and never switched the monitor.
I think it is all the same bluetooth signal. PM me if you are intrested in the monitor in the mirror pictured in my thread.
Ohh the reason I still have it is I sold the car, It is the same stock mirror and I put a ton of work into it, I was going to use it on my SRT6 but opted against it because this wing is not as bad to see over. Let me know WE can work something out...
I hardwired it In and never had a problem with it flickering. If anyone wants to try and tackle this themselves I can help you out on how to put it into the mirror and not have as much trouble as I did. BE PREPARED TO PUT IN SOME HOURS THOUGH>>
