Re: Adding a Supercharger
there is plenty of room in our engine compartment for the rotrex, and even more room for a vortec SC if you relocated the overflow tank from the radiator.
Check out the guys dyno, it's not even tuned very well from the gragh he posted, it should be a lot smoother and could probably make more power if tuned properly. I could probably smoke him in my stock Limited crossfire, that car needs serious tuning! He's hardly making 200hp and about 150ft,lbs. at 4200rpm!
good find, it does give hope. I will have to look into the Apexi ecu he's using.
