Old Jan 1, 2008 | 08:33 PM
Focushere's Avatar
Focushere
Default Re: Getting the top down?
Originally Posted by DenverCrossfire
This is surely a newbie question - I don't understand how to get the top down. I beleive I'm having problems with the trunk.
Reading through the instructions in the owner's manual, there's about six steps for putting the top down. I beleive I'm executing them correctly, of releasing the latch near the front, and then giving the top about eight inches of clearance from the windshield. Yet, when I press the electronic button to begin lowering the top, nothing happens except beeps.
Looking elsewhere, there's some text on moving panels around in the trunk, to make sure there's space to accomodate the top. The text isn't clear to me on this point. I'm really not sure what I'm supposed to be doing. When I open the trunk latch and look insider, everything looks clear to me.
Can someone provide directions, or better yet, pics, or best, a pointer at a YouTube video?
First make sure the panel in the trunk is in the vertical position.
Then with the ignition on, open the top by pulling down on the handle and turning. Push up about 6 to 8 inches and the windows should lower. Now, press and hold down the switch to lower the top. Let go of the switch after the top is lowered and you hear a beep. You must hold the switch down until the top is completely lowered.
Just reverse the procedure to raise the top.
