Re: Running SAT Antenna
rickyms, I have the exact same radio. You can mount the antenna on the glass of the back hatch midway between the top edge and the rear brake light. There's a metal brace right under the glass that the antenna's magnet can stick to. You can run the antenna wire in through the back hatch and then press it into the seam between the head liner and the side mouldings all the way to the front.
