Re: Help With Bulb Replacement
If you have small hands and a lot of patience, you can reach the bulbs through the engine compartment. If you have large hands then you will have to remove the headlamp unit, again not easy and will require a little patience. I believe there are instructions in the owners manual that will tell you how to remove the headlamp unit.
