Old Jan 7, 2008 | 01:58 PM
Steve Hellums's Avatar
Steve Hellums
Default Re: SRT 6 VS SLK32 S/C cooling system
Originally Posted by MMZ_TimeLord
One guy bought a 2 gallon aluminum reservior and put it in the cargo area in the spot for the first aid kit.
He also used very insulating and durable hose. I don't have the link, but it was posted in a thread here on the forums. It was a link to the MB forums I believe.
I am considering this modification myself for later this year.
Cheers!
One thing I was considering doing was to get a reservior with two fittings on the bottom and plumbing it where the pump would be sucking out of the reservior thru the heatexchanger, then from the pump to the inner cooler and the output from the inner cooler back into the reservior to be recycled. I would like to do it that way so you would have more volume of coolant passing through the system thus more time to cool down, rather than it just being makeup coolant. But I do have some concern about air getting into the system plumbing it that way. Hopefully HDDP or someone that would know more about how a sealed system would react to plumbing it that way will chime in here with some input. What's your thought's on doing it this way MMZ_TimeLord?
