Originally Posted by Maxwell
You can remove the tire from the rim yourself, but I recomemd you call a friend who is over 200lbs. it's a little laborous but easy to do, no need for special machines.
just deflate the tire, and you and a friend stand on the side wall to demount the bead, either the outside or inside will dismount easier. after breaking the bead, just slide the remaining tire over the lip of the rim (use soap and water to loosen things up if neccessary)
Be sure to take notice of the the TPMS sensors when dismounting the tires, removing if necessary to get enough
tilt to get the second bead off.
