Old Jan 12, 2008 | 12:10 AM
sonoronos's Avatar
sonoronos
Default Re: Aerodynamics Help
Originally Posted by HDDP
Looks like most tracks will require an 11.5 degree angle for optimal performance (downforce vs drag) Producing an averaged downforce of 212 lbs. While the faster tracks (CAL SPEEDWAY, etc) will require somewhere in the 10 degree range.
HDDP, did you ever end up setting the wing's inclination?
Based on the parameters you've given, the boundary layer separation should cause a stall (zero downforce) condition at around 10 degrees declination. This boundary layer separation can be reduce by inducing vortices before the air reaches the spoiler.
In any case, I'm interested to hear what ended up coming out of this, and what declination you ended up using.
