Old Jan 12, 2008 | 04:45 AM
Buck70's Avatar
Buck70
Default Re: Nitrogen in your tires
Originally Posted by theglot
Article I read a while back stated two benefits to Nitrogen; stable pressure and lack of moisture. Nitrogen will not have any moisture content. If you get air from a poorly maintained pump it could introduce moisture into your tire. Moisture and our TPS do not mix well. Therefore, I run nitrogen in both my vehicles with TPS.
Maybe
FWIW
I watched the psi in my Magnum with the 4 wheel real time monitoring to see how much the pressure swings relative to temperature. Granted the 20" wheel with wider tires is a larger air chamber, but it still proves the point.
The temp swing here in 2 weeks was from 9 degrees to 62 degrees per my dash temp, which has proven to be pretty accurate. The psi swing was from 27-41 psi The heat from driving normally raisies the psi 2 lbs in a 10 minute commute, so use 39 as the top number. That is still a 12 lb swing.
On a lopro tire 27 didn't show an extra bulge and 40 didn't add any harsh feel on a heavy, long wheelbase car. I don't run pure Nitrogen, just the typical mix we all breathe. BUT those numbers do show that in a scenario where inflation is crucial and you aren't **** about checking the psi it could save your **** to run Nitrogen.
Protecting the TPMS is a nice bonus I hadn't considered. Beating the dead horse here brought us another nugget, and a few actual facts to consider
HTH
DB
