Old Jan 12, 2008 | 05:07 AM
Buck70's Avatar
Buck70
Default Re: How Effective Is The Spoiler
Originally Posted by Brent
Wings and spoilers function differently but the end result is the same. First a little background.
The shape of the Crossfire mimics a wing and as a result lift is generated. In order to have lift you must first have a high pressure zone and a low bottom. Look at the Crossfire in would appreciate a basic primer.
How Chrysler determined the amount of downward force generated by the spoiler is beyond me. Part of the problem may be that it actually is a wing and is just misnamed. But from what I've seen of it I would call it a spoiler.
The gizmo on the back of the SRT-6 is a wing. It is shaped like a wing and is designed to allow air to flow over and under it.
The downforce generated is fairly easy with a wind tunnel and load cells. The weight of the car will change with different velocity across the car.
As for the other functions of the gizmo on an SRT 6, I suspect it was related to the higher top speed creating more lift, thus the bigger wing/spoiler/gizmo
The other thing it does quite well IMO is help the look of the car. I'm not hating the base/limited shape just think the SRT wing really cleans up the back of the car style wise.
