Old Jan 12, 2008 | 10:04 AM
04Fire's Avatar
04Fire
Default Re: ESB/ABS Indicator Light
Originally Posted by woody
That's usually an indication of a wheel speed sensor (or related connection) fault. The ABS controller looks for a coherent speed signal from all four wheels when you move off, and will trigger the condition you describe when you get above a few mph. Check the big connector on the ABS controller is seated and locked, and check in the wheel arches (wells) that the speed sensor cables have not been disturbed.
Hope this helps.
Well I checked everything I could and it all appears to be in the right place... So now I'm stuck. Looks like it's back to the dealer monday
Thanks anyway guys!
