Re: Excessive tappet noise on cold start-up
the tappet noise is not from the valve-train, there are a couple things that can make the noise, one is the little electric check valve on the drivers side, the exhaust manifold, timing chain sprocket is not getting oil from the oil sprayer, or the fuel injectors.
You could pick up an automotive stethoscope and trace it out.
