Old Jan 13, 2008 | 07:27 PM
sonoronos's Avatar
sonoronos
Default Re: Long Crank during start
Originally Posted by jrams500
Anyone have a similar issue starting their crossfire. I have an 2005 Roadster and sometimes it will have to crank for 10 seconds or so before the vehicle will start. Any help would be great
Are you sure you cranked the engine for 10 second? 10 seconds is way too long. Longest I've cranked is 2 seconds, which sometimes feels like 10 seconds.
In any case, assuming that your spark plugs are working, then try putting your key in the accessory position for a few seconds to get the fuel pump circulating fuel and bring the fuel rail up to pressure before starting the car.
Next thing to do is attach a fuel pressure gauge to the fuel rail and perform cold-start and hot start fuel pressure checks.
Assuming that your spark plugs are sparking (if the car runs fine, there's no problem), then it's 85% probability a fuel-related issue.
