Got home on Friday after work, pulled the car out of the garage, unhooked the battery and let it sit for about an hour as i played Madden on the Wii
Went back out, hooked it back up, and the car started/acted fine with NO CEL.
The car DID have a hard start issue again yesterday though. It cranked for 7-8 seconds without firing, and then just stopped cranking. (the car 'gives up' after cranking too long, and you have to pull the key out, re-insert, and re-crank.).
There is another dealer I am going to take it to that has an SRT tech. I'm not sure if the car will still have the code after I disconnected the battery or not, but we'll see.
Brian, what were the symptoms of your injector failure?
SQ
