Old Jun 4, 2004 | 11:16 AM
DFWSBR's Avatar
DFWSBR
Default Transmission Popping Out of Gear TSB # 21-002-04 - 03/09/04
TSB # 21-002-04
This covers a small number of Crossfires which had an issue staying in first gear (6spd manual). Built prior to December 31, 2003.
If you are having the issue, reference the TSB above to your dealer.
They can match up your transmission serial number to apply the fix. It includes a 1st gear synchronizer, seal and plug.
I personally have a Crossfire built prior to December 31, 2003 and do not have the 1st gear issue. I would not suggest performing the fix to your transmission unless you are having this issue. It requires it be removed from the vehicle, opened up, and having parts replaced.
