Old Jan 17, 2008 | 06:48 PM
robby363's Avatar
robby363
Default Re: What is this...?
Originally Posted by Andy G
OK
Now I am officially confused. In my pic I raised the brightness on the part I thought Simon was talking about but I think I got this wrong. HOWEVER from other replies the part I highlighted may be the IC pump. Now here's the rub: from other threads on this forum and on the MB forum the IC pump is in the passenger side front wheel well http://www.benzworld.org/forums/atta...-ic-pump-4.jpg (you may need to register to view this)
See also the same thread for access to the IC pump : http://www.benzworld.org/forums/r170...placement.html
Sooooo WTF isit? HAs the IC pump been moved for all Xfire SRT's; or only later models; or is the offending item a supercharged chocolate fountain pump?
I await enlightenment with baited breath
The thing you highlighted is the air injection pump which is also part of the emissions system. I think where the confusion came in, is cars from England have the drivers side on the right side which on most cars the passenger side is on the right side. So not to get confused, if you're sitting in the car the IC pump is on the the right side down near the fog lamp like it shows in the pic from benzworld.org. It should be in the same place know matter what side the drivers side is on. I hope it helps clear up the confusion.
