Old Jan 23, 2008 | 01:28 AM
Steve Hellums's Avatar
Steve Hellums
Default Re: Moving The HE Forward To Add Cooling Fans
Originally Posted by HDDP
Nice job Steve... I think you got something there...
Thanks HDDP !
Originally Posted by jonnyangel04
All I can say is wow I am sure glad I found this tread. Only thing I would suggest would be maybe throw in an LET HE while you have it all apart and a CM30 pump but wow looks good.
The bigger heat exchanger was a thought, but if it was thicker I would not have had room for the fans. The fans need to have room to disperse the air and I don't think I could have moved the HE out any more than I did. The Johnson pump was a thought too, but my car has less then 3K on it so I just couldn't see replacing it till it goes out. This mod will not help at highway speeds, but I think it will greatly improve the performance at lower speeds when there is no air flowing thru the heat exchanger or say at the track sitting around at idol or creeping along speeds.
