We don't have paper manuals past 04 at my shop, however this is our tech support queries. I did some research and I came up with this.
Search Result #
8 of
169 (
58%)
function edit_result () { document.formulaire.action.value="EDIT"; document.formulaire.submit();}
Case Number K28365343
Vehicle IssueMIL light came on . \
Fault present for P0111. |
Intercooler water pump not working
Year2005ModelZH - CrossfireEngine3.2L V6 SUPERCHARGED
System or ComponentMalfunction Indicator Light / MIL / Check Engine LightScan Tool Diagnostic Trouble Codes / Error MessageP0111 $CA
Intake Air Temperature Sensor Performance
Case Verification
Verify the vehicle complaint.
Perform diagnostics for the stored/active fault. Compare the intake air temperatures and the coolant temperatures. If the intake air temperatures are higher than the coolant temperatures, review the below recommendation.
Recommendation
The intercooler for the supercharger is water cooled. If there is premature failure of the intercooler pump, then the intake air temperatures will start to climb up and set the fault. If they get high enough, the ECU will disable the supercharger pump resulting in a lack of performance. Verify the intercooler pump operation.
Modification Date08/11/06 4:48 PM
