Originally Posted by RPM
You don't. You have to get the ECU re-programmed to remove the speed limiter.
FYI - You can't actually have the speed limiter "Removed" only raised to 200MPH - there must be some digits programmed in the ECU and 200MPH is the max. That's fast enough for me (or at least for my tires)
Might as well have the RPM limiter raised at the same time.
BTW - the factory setting on the speed limiter is 155MPH
