Old Jan 28, 2008 | 05:26 PM
RMADERMAN's Avatar
RMADERMAN
Default Re: Lambo Style Doors
Originally Posted by stlouistrucker
Is it more difficult to open lambo doors than stock?
The doors open normally as the stock doors half way out. Then you simply lift them. Neither Ashley nor I have any problem lifting the doors, but the wife thinks they are hard to put upward. In order not to rub the corner of the inner door pads, you have to extend the door outward to its max before you lift them. It does require a certain amount of strength to lift and push slightly outward to properly put up the doors.
It is much easier to get in the car. It takes a little getting use to opening and closing the doors. I become dyslexic and have senior moments and get downright confused when I switch XF's with Ashley and try and get into my SRT. I go to open my door and want to pull them up. I just scratch and shake my head since mine won't go up.
In the words of Danimal, "I need to switch my medications".
