Re: Sprint Booster data collection
I got my Sprint Booster yesterday, thanks Anthony (TVT Design). Installed it this morning with the remove two screws and drop the dash panel method. Not the remove the gas pedal method…
I just removed the two phillips screws and loosened the under dash panel above the brake pedal. I just pushed it up a little to make some room.
Then I removed the panel on the side of the console, next to the gas pedal, just one plastic phillips ¼ turn lock screw holding on the vent piece and one regular phillips screw under the vent - holding on the panel.
With those removed, pull the panel away from vent and then straight down and the panel is removed. I just stuck my hand back there and unplugged the connector along side the gas pedal and installed the sprintbooster.
The whole job only took me 10 min tops…
The SprintBooster works good!
It is a bit touchy though, just a little press of the gas pedal and it snaps your head back if your not careful.
The car responds now like it has a linkage instead of the granny approved throttle curve that was computer programmed from the factory.
