Old Feb 3, 2008 | 07:09 AM
  #39 (permalink)
HDDP's Avatar
HDDP
Default Re: LET Motorsports Phenolic Spacer Sale
Originally Posted by tom2112
Let me get this straight, these spacers go between the intake and the engine block right? And the whole idea is that they insulate the intake from direct heat conduction from the engine block, thus reducing the temp of your intake.
That sounds like a good idea, but won't this also have another affect: raising the temperature of your engine block? I'm no race mechanic, but that doesn't sound like a good idea to me. So I'm curious, can someone explain?
TIA,
Tom
Since the previous post is correct, the heat dissapation from insulated contact with the SC intake plenum will not increase engine temps. I find it really hard to believe EvoSport's original claim of 100 degree drop in intake temps by installing the spacers alone...
Most of the heat soak is being generated inside the IC that is trapped between the SC and engine block... So while you are installing the spacers, insulate the bottom and sides of the IC with ThermoTec insulation.
