Originally Posted by HDDP
Since the previous post is correct, the heat dissapation from insulated contact with the SC intake plenum will not increase engine temps. I find it really hard to believe EvoSport's original claim of 100 degree drop in intake temps by installing the spacers alone...
Most of the heat soak is being generated inside the IC that is trapped between the SC and engine block... So while you are installing the spacers, insulate the bottom and sides of the IC with ThermoTec insulation.
The power of marketing..."these intake manifold spacers help reduce intake temperatures by
as much as 100 deg. F"
http://www.evosport.com/product/prod...VO.PER.32K.PS1
