Old Feb 5, 2008 | 05:26 PM
apkano's Avatar
apkano
Life is random...so am I.
Default Re: SRT8/10 conversion...
Basically......with a chrysler v-8.....you'd be rewiring most of the car. You'd need all the electronic bits from the donor engine. you'll also need to address things like spoiler operation, abs, esp, Switching out the Auto trans (if not a 6M), the mercedes ignition system w/electronic L.C. keys, etc. Basically there's no way to do a "half and half" on the electronic system, Even with the Mercedes "star" software and breakout box. There have been many people who have talked about (and MAYBE tried) to do more engine things, only to find them unfeasible due to the electronics. I think the most promising projects to date have been HDDP switching his to a SRT, and latana's switching to a Mercedes V-8.
But don't let me stop you......I'd love to see someone swap a big 'ol american V-8 .......preferrably this..........
392 HEMI CRATE ENGINE — 525/540 HORSEPOWER
Mopar’s fi re-breathing, 525-horsepower fuel-injected 392 Hemi crate engine is an all-new engine assembly for a new generation of Mopar enthusiasts. Comes complete with a preprogrammed engine controller and harness to ensure compatibility with virtually any vehicle configuration.
Specifications:
• Deep-Skirted Cast Iron Block with Cross-Bolted Mains
• CNC Ported Aluminum Twin-Plug Cylinder Heads
• Stainless Steel 2.100" Intake and 1.600" Exhaust Valves
• Ovate Wire (Beehive) Competition Valve Springs
• Viton Competition Valve Stem Seals
• 279ฐ/285ฐ (duration @ .006") Hydraulic Roller Cam with .584" In,.552” Ex
• Forged Pistons (4.055" Bore)
• 10.3:1 Compression Ratio
• Aluminum Single Plane High Rise Intake Manifold, Holley 870 cfm 4-bbl. Carb.
• OR 80 mm manual throttle body
• 4140 Forged Steel Crankshaft – 3.795" Stroke
• 4130 Forged Steel I-Beam Performance Connecting Rods – 6.200" Length
• SFI-Approved Competition Crankshaft Damper
• “Plug and Play” Wiring Harness
• Premium Tri-Metal Performance Engine Bearings
• Precision Balanced Rotating Assembly
• Distributorless Coil-On-Plug (COP) Ignition System
“Plug & Play” Engine Management System (EMS) Features Include:
• Windowsฎ software
• Built-In Peak and Hold Injector Drivers
• Built-In Direct Drive Ignition
• Built-In Dual Wideband UEGO Controllers (UEGO sensors not required or included)
• Sequential Fuel Injection
• Soft Cut Rev Limiters
• Onboard 512 kb Datalogger
• Definable Knock Control
• Full Idle Control
• Uses all the Factory Sensors
• Complete 392 calibration included
