I looked into it when I sold my Limited and purchased my SRT.
You will need the spoiler panel, the motor, hinges and mounting hardware, the drain tubes, the wiring harness and the switch on center console, a new fuse and make a custom wiring harness from the fuse to the switch - and the system will not automatically deploy the spoiler - it would be a manual task.
Like others - I thought the SRT spoiler was to big - but now I like it - I like it alot.
I believe he is going from limited to SRT, not vice versa.
My concern is the alarms the limited had on it when the wing was inoperable. If I recall, you get a beeping sound if the wing doesn't deploy - and I thought I remembered reading someone's car being speed-limited due to a wing malfunction.
Could be wrong...but I know for a fact that it will at least start beeping at high speeds if your wing is not working (non-SRT).
SQ
