Old Feb 5, 2008 | 07:59 PM
apkano's Avatar
apkano
Life is random...so am I.
Default Re: Looks like GM has their stuff together.
How quickly they forgot the Citation/Cimmaron debacle, eh? Cimmaron, the absolute least worthy car to ever wear the Cadillac badge.
HAHA....the Cimmaron........when the brakes locked up all you had to do was push up on the kick panel under the dash! The clips that held the panel up would fail causing the panel to fall down a couple of inches when the brake pedal was depressed, then when you took your foot off the brake the panel would hold it there for you. Lot of burned up brakes from that damned panel.
How about the HT4100 engine.......you know.....that wonderful piece of engineering! Reliably blew out the side of the block at 30,000 miles. No matter what your problem was with the engine......the service guy always asked the same question......."For a replacement, you want an iron block, or another one of those?"
