Originally Posted by cgocifer
Or engine pieces...
I don't see why you think engine pieces will be on the ground, our NA motors have forged cranks, forged connecting rods, piston oil sprayers, 4-bolt mains, and rigid blocks. the only downfall working against us is the 10.5 compression ratio so we can only boost up to 5-6psi.= 300hp easy, if you want to get serious I recomend srt6 connecting rods and the 3.7L piston and sleeve kit, srt6 water pump and oil pump. by this time I think an aux oil cooler should be installed to fight detonation due to heating the pistons with hot oilsprayers.
