I guess you have trouble reading, I said kleeman can reprogram your ecu for $1000, for low boost kit. I just solved your biggest hurdle now lets get crack a lackin'
Originally Posted by Opticon
The means to force air down an Xfire's throat can be cheap any way you look at it. It's the fuel support, timing control, and tendancy to detonate @ stock compression that are the problems.
If you find a way past those problems, you could rig up 30 leaf blowers in tow-behind and make "mad power".
But if you have the room, turbocharging is a much better solution due to both it's efficiency and fuel economy.
EDIT: I really shouldn't be researching anything close to forced induction on my crossfire due to the warranties I have... But I've been too deep into the turbo dodge community to leave well enough alone.
On that note, I'll be pondering ways to get around returnless fuel systems and MAF setups for a good long while.
