Automatic Sprint Booster Group buy
Feb 7, 2008 | 07:47 AM
111
permalink
Valk
Jul 2007
18,118
1,604
Aurora , ILL
Re: Automatic Sprint Booster Group buy
Quote:
Cali_Boy_4_Ever
how hard is instalation and can I do it myself
INSTALL INSTRUCTIONS AND PHOTO LINK
I just to put together this post in the thread
"Sprint Booster Install"
because when you do a search it brings up many other threads on this subject. Thanks to all who have posted this information on various other threads.
This post summarizes the info needed for newer members now buying and installing Sprint Boosters.
Here are step by step photos for option 1 thanks to PAULW in this link
https://www.crossfireforum.org/galler...ry.php?cat=574
Option 1
You need to remove the throttle pedal following step below
1. Remove the lower nut cap.
2. Remove the 10mm nut.
3. Remove the washer, a magnet helps.
4. Remove the pedal, lift the bottom pulling out and pull it out of the upper bracket.
5. Unplug the tps cable from the sensor.
6. Plug the tps cable into the
Sprint Booster
7. Plug the
Sprint Booster
cable into the tps sensor.
8. Reinstall the pedal assembly.
9. Go for a test drive, you WILL SMILE !!!
Option 2
(No photos)
This is another method of installation :
Remove the kick panel on the console
This is the panel that is to the right of your foot as you sit in the car
All you need is a Phillips screw driver! First remove the screw on the drivers side lower console where the vent is, 1/4 turn; this is a locking screw. Remove the second Phillips holding the lower drivers side console panel. You'll have to do a little removal manipulation of the panel, but it bends quite easily; its plastic! You may have to depress the gas pedal for clearance and temporary removal. Note: Always take note of how things fit a feel prior to panel removal, its just a good code to follow.
Look at the top of the gas pedal and there is the plug. Squeeze the sides to release the locking mechanism on the plug. Unplug and insert the SB. Replug the plugs with the SB in line. Replace console side and screw and then the vent and screw and now you are done!
Valk
View Public Profile
Send a private message to Valk
Visit Valk's homepage!
Find all posts by Valk
