Old Feb 7, 2008 | 10:00 AM
BRappaport's Avatar
BRappaport
Default Re: Oil Change with Topsider or similar
To those who use the topsider to perform there oil change...
In order to not soften the tubing on the topsider, how long do you run your engine from cold start to heat up the oil for better flow removal?
Also, when pumping out the oil, does the tubing get real hot to the touch?
I do not want the tubing to get soft and collapse.
Thanks
