Originally Posted by ShawnQ
Any supporting evidence?
Check the mercedes boards if you don't believe me.
Here's an easy test:
1. Use AC Multitester
2. Disconnect CPS
3. measure AC voltage across cps while cranking.
4. if you have voltage, then the CPS is fine. If you don't have voltage, then your CPS is broken.
Have you noticed that the problem is getting worse over time?
